Picture messaging does not work -
Milk
  • My plan does include  --------"Unlimited International Text and Picture Messaging".
However when my monthly data runs out  I can not sent or receive pictures without data. I did read past posts on this subject and have followed advise such as to check APN settings etc but nothing works - My APN setting is asp.mb.com - is that correct?
27 REPLIES 27
maximum_gato
@Milk
There does not appear to be a "wine" community account. The info you recieved was incorrect.
Edit:
Maybe it's coffee break time?
Milk
Yes I did ask friends and family members if they use this forum. The only family member also on this forum is Beer who initially did also setup my (Milk) account. I can’t find the wine account so that I may see their posts and maybe private message. In the search bar I tried typing wine and @wine but nothing happens. How does one search other members?
If it's true that you're in the same household as the other users then use the forgot username/password link and try email addresses. Check those emails and see if the password reset arrives.
Milk
You say that wine is one of my accounts -- can you please give me or tell me how to get it's password so that I may check it out.
@Milk wrote:
self-given solution removed --that is not true--you are making assumptions because of the ip address -if for any reason I wanted to fool anyone I could just have re-booted my modem - and yes every time I reboot it generates a different address -- what possibly would I gain by trying to deceive ----    give me a break!
*******Your internet provider assigns a public, dynamic IP address to your router or wireless gateway. When you reboot either device, it receives a new IP address from your internet provider
@Milk, it has long been known and admitted by Beer, that Beer, Wine and Milk are all the same account holders/ or family.  There are other users that have been linke and I think Tsawwassen is one and not sure if there are others.  It doesn't matter if you post as them in them in the community but to give them the solution is frowned upon and considered gaming.  There is no need for the solution when in fact this is a family member that you could have asked within your household or even if they didn't live in your house.
As stated Oracles do not have access to IP addresses so there is no way we can look at them to compare.
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
I do not have access to your IP addreess.  However, as rewards are based partially on solutions, it isn't fair to everyone to give solutions to yourself, to your other accounts, or to family members who are possibly in the next room.
Milk
maximum_gato
@Milk
Data speed shouldn't affect sending/recieving MMS. Go to your messaging app in your Settings>> Apps>>Messages (not iMessage) >>Storage and clear the app cache. Try sending an MMS text and see if it improves the timing. Forgive my instructions as I'm an Android user so getting to your messaging apps storage may be different.
Milk
Yes - I think that the problem is that my 3G plan is too slow - when I use iMessage pictures are almost immediately received  and sent.  I was expecting the same performance while sending  / receiving by MMS. During my test earlier, pictures that I had sent  and had sent to me were eventually delivered but many minutes later. Later tonight I plan to try out one  of the 4G plans with plenty of data .
maximum_gato
@Milk
MMS does not require any account data to work. The bf runs out every single month and can still send MMS even the dumb ones that he thinks are funny. Don't give up....it's better that you learn how your iPhone works rather than pay to blissfully ignore your settings.
@Tsawwassen wrote:
As several other have advised you in perhaps not in simple terms --JUST----- disable iMessage and try again -- --
Your MMS will work once you turn off the iMessages option and you make sure the mobile data is on. this type of messages don't use MB.
I know your time is valuable, and I appreciate your attention.
Tsawwassen
popping
@Milk wrote:
Yes -- yes we all know this -- the easiest solution is for me to buy some data - and be done with this. Thanks to all for trying to help ---
@Milk
It is up to you if you want to pay more.  PM will thank you for your extra spending.
I have a PM plan without data and I have an iPhone 12. I am using the following settings and my iMessae app is showing blue and green bubbles.
Settings  ==> Mesages ==> enable
1.  Send as SMS +
2.  MMS messaging +
3.  Group Messaging
Enable cellular data.
The easiest thing is to turn on those options, turn off imessage, turn on cellular data, restart phone and try.
Or try in another phone to verify that having no data stops mms. Again, I doubt it.
Milk
Milk
There are many posts reporting this problem - just perhaps you have never been without any data.
popping
@Milk wrote:
@dust2dust wrote:
Cellular data. Imessage has an option send as mms (also send as sms). Turn both on. But again cellular data needs to be on.
Yes - but all is well as long as I have some data - ----- but my data has run out so picture messaging does not work - Will just have to buy a data add on and be done with this. Thanks to all for trying to help.
Yes, iPhone iMessage is using mobile data to send and receive.
What is the color of the message you send/receive?
Blue bubble = using iMessage which use mobile data only
Green bubble = using MMS which uses a specific data server which is free and for MMS only.
If you are using Blue bubble,  you need to enable SMS and MMS in the iMessage settings.
Unless this is a new thing from them, I doubt it. Have you restarted the phone? Can you try sending an mms from a different phone with your sim in it?
You would be the first that I can remember reading recently that this might be a thing. I doubt it.
Milk
Milk
Thanks for help - can't find "turn on mobile data" on my iPhone 11 - tried sending a small picture by turning off iMessage and leaving MMS and still  picture didn't sent.
dust2dust
Jeez imessage is crazy making.
But this could be a new thing. I doubt it. But could. For years it has been that mms would work even on plans with no data. Cell data just needs to be on.
HI @Milk
dont' get mixed up
you need to know if you are sending MMS or iMessage
with MMS , you have to turn on Mobile Data but it would not deduct your data.  So, you just need to enable Mobile data and you can still send even you are out of data
with iMessage, you need mobile data and it will use data
So, if you already enabled data and you cannot send out due to all data used up, then you are sending iMessage.  You just need to change it to MMS and you can send
Milk
It's an iPhone 11 -with latests IOS updates--  Pictures definitely do not sent without data - and only texts sent when data and wifi is turned off. It's always been like that. It's become a problem now because I completely ran out of data until of course my renewal date later this month. I asked a couple  of my friends also on PM and they also confirmed that without data turned on picture messaging also does not work for them. Could this be a problem with PM? Now I"m will be forced to purchase a $15 + tax data on on - doesn't seem fair.
Meow
To use MMS your DATA has to be on even though data allowance will not be used.
Use native texting app, not 3rd party - proprietary app for SMS/MMS.
dust2dust
Is this an iphone? The apn should not have the 'a' in front.
But if browsing works then the apn should fine. Is there an mms apn settings area?
hairbag1
@Milk
that apn looks correct.
added
I found this in the PM Help Articles...
https://www.publicmobile.ca/en/bc/get-help/articles/mmsbrowsing
