Phone transfer
Alice1998
Hello I need help with transferring my number. I  joined public mobile and they gave me number about 2 months ago and I am now transferring my old number and I am able to call but not receive calls. Should I do anything in my end. Didn’t get a message or notification that the transfer process is completed. Please help
9 REPLIES 9
hi @Alice1998
did you call the number I sent you?
if no success there, then ask support agent to check by a proper ticket
 submit  ticket by direct message:
Alice1998
It’s an e-sim. Is it possible to go back to my number that public mobile gave if this doesn’t work
@Alice1998
did you have your old sim in the cell when waiting for the port confirmation text ?
Alice1998
Yes I did.. but never got a port transfer message
hairbag1
@Alice1998
during the 2 mos that you've been a Public Mobile customer, did you keep your old account / number paid up ? Your old account needs to be active and in good standing in order to port successfully.
Alice1998
That number said they can’t help with public mobile
Alice1998
I think my portions stuck..how do I fix this
Dunkman
@Alice1998
Did you receive a port request text from your previous carrier?  Did you answer yes?
When did you initiate the port?  It can take 1-2 hours for the port to be completed. If it has been more than a couple of hours, then your port is stuck.
hi @Alice1998
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
