a month ago
I changed my provider from freedom to public and freedom already sent me email of cancellation of service .. but in my phone setting - > sim -> primary cellular shows freedom . I didn’t make any call .. almost 10 hrs gone to do transfer of phone
a month ago
yes, remove Freedom physical sim, then go to Settings -> Sim menu and
enable Public Mobile sim and set it to Primary. Then Reboot phone and Reset network settings
a month ago
I was using freedom sim but for public mobile eSIM . Shall I removed removed freedom sim from my phone
a month ago
you see the Public Mobile sim in the Settings -> Sim menu?
if you do, you need to disable Freedom esim yourself. Then enable Public Mobile sim and set it to Primary. Then Reboot phone and Reset network settings
