06-06-2020 03:25 PM - edited 01-05-2022 11:03 AM
06-06-2020 04:57 PM
Here is more info about what to do.
https://www.publicmobile.ca/en/bc/get-help/articles/lost-or-stolen-phone
06-06-2020 03:57 PM
@Chadbute_1991 reset your password using the reset link.
06-06-2020 03:41 PM - edited 06-06-2020 03:55 PM
@gblackma wrote:@Chadbute_1991 you can use 1 855 4public amd your 10 digit phone number once you know your 4 digit pin code and dial into 611 amd remove your credit card.
No you can't. You can only toggle on/off autopay.
Edit: it doesn't touch the registered payment card...just autopay.
06-06-2020 03:37 PM - edited 06-06-2020 04:11 PM
@Chadbute_1991 you can use 1 855 4public and your 10 digit phone number once you know your 4 digit pin code and dial into 611 and remove toggle your credit card off. Once done make sure to change your credit, bank, email passwords.
Contact the the moderators. Type help phone stolen can't remember self service account password."
There are 2 ways to contact the Moderator Team:
Keep an eye on the envelope top right of your screen. The mods answer will show up there. Stay safe.
06-06-2020 03:32 PM
@Chadbute_1991 wrote:my phone was stolen dont remember my password what can I do
@Chadbute_1991 Log into your self serve account and click the plans/add-ons tab, then the phone lost/stolen tab and suspend service.
If you can't remember the password to login to your account, then submit a ticket to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
Type in your issue and select contact us/moderators, then submit ticket when these options appear and follow the prompts to finish.
