Phone service
03-02-2023 01:14 PM
03-02-2023 02:46 PM
Yes it is. I have better luck with the pin option rather than the login option after re-logging in with the community login.
03-02-2023 02:44 PM
Thank you for your help. I have submitted a ticket.
The ticket submission process is exasperating.
03-02-2023 01:23 PM
There have been issue since yesterday for some people with both incoming and outgoing calls.
Try to change to 3G only and see if it connects to the network at all with such settings
If both incoming and outgoing calls are not working, I suggest you to open a ticket with PM support and let them aware you are one of those affected, too
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-02-2023 01:19 PM
There are currently no outages in Cranbrook. Try the following…reboot phone, reset network settings, reinstalling SIM card. Also try setting preferred network settings to 3G.
If you call 611 does it say your account is active?
03-02-2023 01:17 PM - edited 03-02-2023 01:18 PM
@Lucasbran Try testing network settings and reboot the device could be issue in PM side as there been a few posts about this happening to many
