an hour ago
21m ago
Request a fix
31m ago
@Scottye wrote:Please submit a ticket for customer service thank you because my payment went through and everything is good on my end and still no service this has happened before and it's on public mobile end to fix every month this happens
What did you do in the past when this happened ? If you contacted Customer Support and they got you going...just do that again but tell them the issue is chronic and request they fix.
33m ago
I can't submit a ticket for you. You will need to submit a ticket yourself. Click on the link that I provided earlier. Or when you login in your account, on the left side, click on Messaging Centre icon and follow prompts to submit a ticket. You will get a response within a few hours
38m ago
43m ago
You could also try to toggle airplane mode on, wait a few minutes, then off.
In the past, we have recommended that customers report their phone lost (which suspends account). Logout and then log back in. Report your phone found.
Otherwise, you will need to get customer service help:
You will need to submit a ticket for Customer service agent
52m ago
Can I get a call back as my phone is active and I did what was recommended and it's still not working
an hour ago
Please check My Account and confirm if account status is active
Reboot phone and Reset Network Settings
