08-24-2026 02:53 PM
Why is it that when I log into the website compared to the app? It is a different password and it will not allow me to log into the app with that same password.
08-24-2026 04:48 PM
Strange, you should be able to login on the app and website using the same login ID and password.
08-24-2026 03:08 PM
Did you ever change them so that they are different?
If yiu can sign into both the app and the website successfully, then change one of the password so that theybare the same if that is your preference.
Clear cache first so that the information is new and doesn't confuse you.
