06-18-2024
10:42 AM
06-22-2024
11:24 AM
Dunkman
Trying to keep my old phone number. But they keep asking me to choose a new one
06-18-2024 10:56 AM - edited 06-18-2024 10:57 AM
If your plan was a prepaid plan with Koodo. You will need to pick a temporary number and a CS_Agent will complete the porting of your number.
Also, if your plan with Koodo is closed then you can’t port your number over and you will need to pick a new number. Check with Koodo on the status of your old account.
06-18-2024 10:43 AM
hi @Rick29
you are activating new line using the app?
are you porting in from Koodo prepaid? or Koodo postpaid? or from anther provider?
and check if your number can be ported into PM using this link
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
