Phone number doesn't show up in setting
Yurara
  • Hello,
I was able to transfer my number from the previous provider to public mobile.
However, under the phone settings-sim card, my phone number is showing as unknown.
Will it be updated or it's normal???
I bought a subscription two days ago.
Thanks.
13 REPLIES 13
Yurara
I really hoped it would work.
But no... 🥲 But thank you.
Jedi1
On one of our lines when we transferred I had to turn off the eSIM and then back on and it worked after that.  Just another thing you could try if you have not already.
Yurara
Hi
I just tried resetting network but still doesn't recognize my number lol
I don't know what happens here
But thank you for your help
HI @Yurara
it is physical sim,right?   if it is , take the sim out and put it back
if eSIM, no, you cannot "reinstall"
Yurara
Can I reinstall the sim ? Oh I don't know how.. Hmm.
I may need to contact public mobile service centre.
Thanks
Yurara
I downloaded E-sim so I don't have a physical SIM card... 😞
and @Yurara
try also "reset all networks" on your phone, it will refresh everything with the carrier, it might fix the problem
HI @Yurara
do you have another phone? put the sim there and test
or if you just have the pixel phone , take the sim out and put it back after and check
@Yurara
it's a long shot but try removing the sim..then re-installing. See if that kick-starts everything to work properly.
Yurara
Yes it's working fine.just the sim doesn't recognize my phone number.
I am using pixel 4a. I restarted the phone numerous times but still showing unknown.
I am not sure I can manually update it.
Thanks 👍
Yurara
Thanks 👍
hairbag1
@Yurara
can you call out and others can call you successfully ? Is text and data working as expected ?
Hi @Yurara
your inbound calls work?
Try reboot the phone
what phone you have? some phone you can manually update it
