11-18-2022 11:09 AM
My phone line has busy signal all the time and nobody can call me. How can it be reset?
04-05-2023 03:04 PM
Thanks
11-19-2022 01:00 AM
@Hummyleung wrote:My phone line has busy signal all the time and nobody can call me. How can it be reset?
Just in case you have inadvertently call forwarded your phone, dial ##004# and ##21# to reset all call forwarding.
Also, can you call out OK? What happens if you call your own phone number? (You should reach your voicemail normally)
Are you new to public mobile, and if so did you port your number in from another provider? If so, there's a chance your number port did not complete and your number has been disabled at the previous carrier.
11-18-2022 11:38 AM
@Hummyleung , do you have some sort of call blocking set on your phone or maybe calls are being forwarded?
11-18-2022 11:34 AM
11-18-2022 11:13 AM
Is your account active?
Can you try your PM SIM in another phone?
Did you try to reboot your phone?
