Call forwarding: connection problem or invalid mmi code
omin
I'm trying to program my Call Forwarding but I'm getting the following error:
Public Mobile Message
Call forwarding
Connection problem or invalid mmi code
Reference:
https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding
1 REPLY 1
LitlLdy
Call forwarding
Reference:
@omin , that’s actually an ongoing issue for some Customers. I had to create a support ticket to get a CSA to fix it for me on their end for my service! Now it works fine!
  • Get help with your service or account by starting a conversation with the virtual assistant, SIMon. It can help you submit a ticket to the Customer Support Agents. Click here to get started and type Customer Support Agent, then select Contact Us, then select the topic that matches your request.
  • Alternatively, you can send a private message to Customer Support Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
