a week ago
- last edited
Sunday
Dunkman
No longer goes to VM when phone is off/busy!!! Same thing happens on my wife phone.
3 hours ago
@slusagm I have tried different phone still same issue.
3 hours ago
if yours physical sim, try it on another phone. This just to rule out not problem with phone settings itself
3 hours ago
@slusagm I spoke to tech team today. I had argue with them she said It should complete the ringing cycle before going to VM even though my phone is not reachable or switched off.
3 hours ago
I think you did get my point, reply them and tell them it didn't work, not normal and you tried different numbers
3 hours ago
@slusagm I think you didn't read my original full topic. I have already done all steps you mentioned to me. Tech support reached to me today after ticket open and said it is normal. That's how it supposed to work on new network which doesn't sound right to me. Thanks for your effort!
3 hours ago
something now right. Your number was correct, and so do mine
I would ask PM to reset it on their end. Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
4 hours ago - last edited 3 hours ago
@slusagm It has +16475804001 in voicemail. When I am trying to update it with the one you gave, its giving an error " your voicemail number can't be changed
4 hours ago
I don't know if this is the issue but worth a try.
You can type the visual voicemail from the settings drop down menu to explore.
Swipe down from top of phone to settings,
Top right corner radio or 🛞 button (lol)
Click it
Settings menu opens with 🔍 click and type what you are looking for.
4 hours ago
go to dialpad, click 3 dots on top right, clicl settings , then Voicemail and Voicemail number, is there a number there?? try update to +17785804001
4 hours ago
I am using android s24 ultra. I can't find visual voicemail setting.
4 hours ago
@Mavi do you have visual voicemail on? If so, turn it off in your phone settings and see if this will help.
4 hours ago
I just tried that. No help.
4 hours ago
Tr Reset all conditional call forwards and let it go back to voicemail as default by dialing ##004#
5 hours ago
No longer goes straight to VM when phone is off or not reachable. It goes to VM after completing the ringing cycle. Same thing happens on my wife phone. I spoke with PM tech team. They issue the ticket and said this is new thing on 4 g network ( that's how it supposedto work). I just need to check, does your phone does same thing if its not reachable?
a week ago
I did, it's been set up.
a week ago
reboot your phone once. Then on the dial pad, dial ##004# and Send
try try Voicemail again
if that does not work, you will need to ask PM to refresh your VM
a week ago
When I long press1, it takes me to my voicemail. Which means VM is set up.
a week ago
@Mavi have you tried long pressing the "1" from the phone keypad to see if it connects to your voicemail? You may need to redo the voicemail setup. Below is the link to voicemail faqs:
https://www.publicmobile.ca/en/on/get-help/articles/voicemail-faqs
