02-19-2021 10:10 AM - edited 01-06-2022 02:08 AM
I have a phone with Public mobile that isn't accepting incoming calls. I can't seem to get this issue rectified. Anyone else deal with this?
02-24-2021 12:45 AM
I'm happy to hear its been resolved. BTW....if you want address another member just tap the "@" key and a little box will pop up with usernames in it just tap on the name....or keep typing til the name you want pops up. Welcome to public mobile!
02-22-2021 03:34 PM
Tried these things. My old company didn't port my number is what I found out. Public issued new one. Thanks!
02-22-2021 03:33 PM
My old company didn't port the number so they just issued a new one.
02-22-2021 03:32 PM
Found out my old company didn't port the number. all resolved. new number sent. thanks!
02-20-2021 10:08 AM
02-20-2021 09:20 AM - edited 02-20-2021 09:21 AM
How long have you had this issue? Are you saying all calls go straight to voicemail? Or are not being recieved at all? Have you recently unsuspended your account?
Usually if all calls go to voicemail and you need your phone working asap you can fix this issue yourself by logging into your account. Go to the plans page. Choose lost/stolen. Suspend your account. Log out. Wait 1 min. Log in. Resume your service. Log out. Reboot. Test.
Only try this if absolutely necessary as it will trigger the glitch causing your rewards to not be applied during renewal. So either way you will have to contact the moderators to reset your account and/or reprovision your sim card or contact them after renewal to get them to apply your rewards manually.
02-20-2021 08:47 AM - edited 02-20-2021 08:47 AM
HI @mwassink
Check the 4-digits of your SIM match the 4-digits listed on your SELF SERVE account, found here, under "Change Sim Card":
If they MATCH - GREAT!
Try one or more of the below:
*turn off your phone, leave off for at least 3 minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
If the 4-digits DO NOT match, then it appears someone has been fraudulent (SIM-jacked) on your account.
Change passwords and security questions to your SELF SERVE account right away, and check your financials.
Let the moderators know about this as well, submit a ticket here – to be connected to the Fraud Management Moderator team who will be able to restore your original SIM card.
02-19-2021 10:17 AM
Did you recently port your phone number over to PM ? If you did then you need to contact a moderator by submitting a ticket.
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
02-19-2021 10:16 AM - edited 02-19-2021 10:18 AM
Hi @mwassink
Do all other calling features work?
How are you sure that incoming calls aren't working if you can't get them? Presuming you're in the same room as the person calling your number?
Is it possible you have phone turned to silent, and all calls are being directed straight to voicemail, thus the phone isn't ringing or vibrating at all.
I would try rebooting phone, then reset your network settings.
If that still doesn't work, contact Moderators to inquire:
To contact a moderator, there are 2 methods:
