09-28-2023
05:00 PM
09-28-2023
07:06 PM
computergeek541
09-28-2023 05:46 PM
There's no wifi calling feature here unfortunately. The speed has no bearing on reception. For calling, you can set your phone to 3G UMTS WCDMA and see what you get. Texting and data would also work there. You could keep it on 4G LTE (and the rest). If it's currently on 5G then maybe leave it on 4G anyway.
09-28-2023 05:46 PM
@Meow wrote:Radio wave is the same for mobile phone. Difference is the data speed.
Your metal roof might perform as Faraday cage blocking signal. Try to be close to window when using mobile phone. It might (or not) help.
I did some searching and found no specific data that confirms cellular impact from metal roof.
09-28-2023 05:46 PM - edited 09-28-2023 05:46 PM
@GD3 both your phones have VoLTE and compatible with PM and likely using it now.
Try to either disable it, if the VoLTE toggle is there, or change the network mode to 3G to let the voice use 3G
09-28-2023 05:44 PM
Thanks for the link. There is a Telus tower close to me.
09-28-2023 05:43 PM
Thanks for your response. There are places in the house that are more reliable, but outside in the backyard, we have perfect reception.
09-28-2023 05:40 PM
Hello, this problem has just occurred to both of our phone. It started about 2 months back. I use a Motorola G stylus 2022, my wife has a Pixel 6.
09-28-2023 05:37 PM
09-28-2023 05:22 PM
@GD3 , check the cell towers in your locale. It might be that there are no towers nearby.
09-28-2023 05:10 PM
ehat brand and model of your phone is? wonder if it supports both VoLTE and 3G
and it is always a problem or just happens lately?
09-28-2023 05:07 PM
The 3G, 4G, 5G naming is all about speed. I would say you have a reception problem exacerbated by the metal roof. Can you find sweet spots around the house? Or just windows? Or just facing one direction?
