09-28-2023 05:30 PM
Hello @CS_Agent ,
I need some assistance on a public mobile account. I cannot find the email that was used to create one of the public mobile accounts that I have created. I need to suspend services on the account, but I am unable to sign in to get this done.
What information do you require for me to complete this? I can validate billing information, as well I can provide any details from the device the SIM card is in.
Thanks,
Drew
09-28-2023 05:43 PM
Thanks for the suggestion. I did not use one of my standard emails for this account, so I am not able to trace it back to the account which was used to sign-up. We have a few accounts which are associated to different emails. Unfortunately I made a mistake transposing this email, and am now locked out.
I wish that Public Mobile had the ability to associate multiple lines from one account.
09-28-2023 05:40 PM
Did you try the forgot email link on the login page? It'll ask for the the phone number of the account and then send an email to the registered email address. Then check any and all emails you think you might have used and see if it arrived.
09-28-2023 05:34 PM
Thanks for the quick response, Meow. I'll see about contact an agent directly.
Cheers!
09-28-2023 05:33 PM
You have to create a ticket or contact agent directly. Agent will ask you few security questions to confirm you are you and then will reveal or change email for you.
To Contact CSA-agent: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Just type ‘ticket’ and follow prompts. Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly: send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
