Phone compatibility
TheMichstache
I'm trying to find out is a phone is compatible with public mobile, but the checker doesn't seem to be working. It's the Black view bv8800. I have the bv6000 and it works just fine but I wanted to check for this one.
Specs for blackview as to connectivity give me this for 4g:
TDD: B34/B38/B39/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B25/B26/B28a/B28b/B30/B66
@TheMichstache  You can always confirm with support that it will work . To be safe
send a  private message   To CS_Agents
It will work on 3G for sure but 4G 8/11 it says. And no 5G.
Ps: meant to reply to you
and @TheMichstache
your phone has 3G, right? you need the 3G bands for voice.  VOLTE won't work on your phone
HI @TheMichstache
you phone should work here
these are the bands we use here
3G:  we need band 2 and 5
4G:  we need band 2 , and 4, and 5 and 7 and 12 and 13, also 17 and 29 and 39 and 66
