Phone Compatibilty
Canlab
I have been talking to an agent to determine if a Huawei Honor 8X Model JSN-L23 is compatible with PM. The information I have received has not been helpful. Can anyone advise if this phone is compatible with PM?
8 REPLIES 8
@Rastin wrote:
Is It a Chinese market phone? Is so does it run harmony os. If it does you are probably better off getting a new phone. As you won't be able to download the app to activate the sim.
JSN-L23 was intended for sale in the US.
Rastin
Canlab
Will the phone work for text, phone calls, email and data?
Chalupa_Batman
I would never use anything from Huawei in Canada. More and more electronics from them are being banned from Canada for spying on people. They've been caught adding spyware to their phone that can be accessed from China. I'd try a different phone.
The response from 4 years ago hasn't aged well.  These days compatibility is measured against 4G bands and to some extent 5G bands.  3G barely works for data and calls.
The phone will work, but it is an older model.  If you don't already have it and are thinking about purchasing it, I highly recommend not buying it.  This phone will most likely not be able to use VoLTE at Public Mobile.
will13am
@Canlab , this phone has very limited compatibility.  I would suggest that the user experience will be bad.
