12-29-2022
02:39 PM
12-31-2022
10:56 AM
Dunkman
I changed from at 5GB 3G plan to a 15GB 4G plan on November 22nd and since then I am unable to send SMS.
The following works fine:
- receiving SMS
- Data
- Calling
The only thing that is not working is sending SMS.
I am trying to fix this before the New Years as I want to respond to that free 2GB text promo.
Service
12-29-2022 04:44 PM - edited 12-29-2022 04:54 PM
Hi, I tried the SIM card in another phone and it had the same problem where it could not send the SMS.
I contacted the CS Agent as well. Maybe it's my SIM card?
12-29-2022 02:41 PM
@drowsell there has been similar reports before
But try to first reseat your sim card (power off , take out sim card for a minute, then put it back in and power on)
If still does not work, try to "Reset All network" (but please note all your saved wifi will be gone, too, you will need to rejoin the wifi network)
You can also try your sim card in another phone. This will force a reprovision of your sim card/account and it might resolve the problem
If nothing works, please open ticket with PM Support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-29-2022 02:40 PM - edited 12-29-2022 02:41 PM
That change should have no impact on you being able to send SMS, @drowsell
Try rebooting your device, or using the SIM card in another working device to see if you can send texts from it.
Also, try disabling things such as iMessage or Chat (android) to see if the message you send will divert from that service to SMS message.
