Change subscription
Lallbhagwant
I want to change my subscription to newly advertised $29 5G Can-US-Mexico plan with advantage of 100 inernational minutes as compared to my current $ 29 plan.
But when i start  changing it in my account, this new plan does not appear in my account.
Please help me to change to new $ 29 plan
2 REPLIES 2
funpig1
@Lallbhagwant
Is there a plan that is cheaper than $29 available in your Change Subscription.  If so, you could change on renewal and downgrade to the cheaper plan. Afterwards, the $29 might become available to you.
funpig1
@Lallbhagwant
Unfortunately, if that $29 20GB 5G CAN-US-MEX 100 minute plan is not available in your Change Subscription, you will not be able to switch to it.
