Payment of add-on
Teeter63
I have made a top up payment for minutes. How long does it take until I can make outgoing c
9 REPLIES 9
Teeter63
I thank you so much for your help! I was able to successfully resolve my problem using the direct messaging to a CS agent. Your links were incredibly helpful! So grateful!
Teeter63
hi @Teeter63
if possible, try your sim card on another phone
or ask PM to check the account for you.   submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
@Teeter63 wrote:
Yes I did, and I still can't make out-going calls. I am able to receive calls.
So you're sure you bought the Canada wide Talk Booster for $5 ? Log in on the app to confirm you got the correct add-on, successfully. It should work if you did.
Teeter63
And yes I am on the 15$ plan.
Teeter63
@Teeter63
Are you on the $15 plan?
Did you purchase the $5 Canada-wide talk booster Add-on?
HI @Teeter63
make sure you reboot the phone as well
Teeter63
It must be a technical issue because I can receive incoming calls but I am unable to make outgoing calls. I always get the message I have run out of minutes.
hairbag1
@Teeter63
should be as soon as you pay and make the selection. Immediately.
