11-17-2022 04:52 PM - last edited on 11-17-2022 07:14 PM by computergeek541
Trying to reset my password, but won't wok. Keeps telling me an error has occurred. Tried different browsers. What can do?
11-17-2022 04:57 PM
Hi @Ehoganmw
try clear cache first, then restart browser
or try Incognito mode ot Private mode
if still not work, open ticket with CS Agent
at : https://publicmobile.ca/chatbot. then type: "Forgot log in information", then follow the prompt
if you cannot get through chatbot to open ticket, message them here instead:
11-17-2022 04:55 PM
@Ehoganmw Have you tried incognito/private mode too?
If you're unable to reset it yourself, then submit a ticket or send a private message to support. Here's couple of links, try chatbot first.
chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-17-2022 04:54 PM
Use incognito mode in Chrome Browser! It shall work hopefully
