04-07-2018 01:22 AM - edited 01-05-2022 04:34 AM
Is it possible PM service can support apple watch 3 LTE service? I can't find any solution on that.
04-09-2018 08:30 PM
I notice that dead SIM cards are bought/sold in bulk (batches measured by weight in kg or even tons) on eBay. Specifically for the purpose of reclaiming the gold. For buyers who have access to industrial baths filled with molecular acids and cyanide reagents, lol.
04-09-2018 08:07 PM
@Korth I'm pretty sure that downside is exactly what @stonechucker was reminiscing about!
As long as the carriers open up the ability to enter in eSIM numbers during activation or via self-serve for existing clients, it can be "somewhere in the middle" in terms of convenience, while still being a big step forward for the environment (how many of those SIM cards are produced, shipped, used, and then thrown in the trash, and what kind of carbon footprint does that create? I'm guessing a significant amount.) and continued hardware miniaturization (no more need for removable tray and phsyical SIM card).
04-09-2018 07:57 PM
@stonechucker wrote:Remember when you didn't have to put a SIM card into your phone? It was all done via manual entry at the store.
Remember the downside, too. The end-user didn't have the option of quickly swapping phone service to another phone, or swapping phone services on the same phone. Always had to go back to the wireless store/kiosk, wait in line, and deal with reps (which can be a real hit-or-miss experience which varies from store to store). And always had to pay some sort of "reactivation fee" or "service fee" or other surcharge (as opposed to the one-time cost of a SIM card).
I much prefer the flexibility of user-swappable SIM cards. Hate being locked in to anything, even if it's just "soft lock" into reporting/paying for service which I could otherwise do myself.
04-09-2018 02:23 PM
@stonechucker essentially yes, this would be like the old CDMA days when we didn't use SIM cards.
04-09-2018 11:29 AM
To me, it sounds like backward movement on BYOD options.
What's old is new again!
04-08-2018 08:25 PM - edited 04-08-2018 08:31 PM
@srlawren wrote:... the Apple Watch 3 LTE does not have a SIM card slot in which anyone could put their PM sim to test it. Instead, the watch uses an "eSIM", which is built into the device. That's the crux of the issue, that PM does not yet support eSIMs.
Good catch @srlawren!
Apple says "... introducing a built-in eSIM that is over one-hundredth the size of a traditional SIM card, making over-the-air activation possible without compromising space."
"eSIM" means "embedded SIM" ... it still has all the functions (circuitry) of a SIM card but it's built-in, integrated, permanent. The GSMA is trying to promote eSIM with emphasis on end-user advantages:
"The information on it will be compliant or rewritable by all operators, meaning a user can decide to change operator with a simple phone call. A new SIM will not be required, nor should there be any time delay in switching the eSIM to its new purpose. There will also be no physical swapping over required by the user."
Although the real appeal is to device manufacturers. It's reduced to a tiny bit of silicon, it doesn't even have to be a discrete part on the mainboard if it's integrated within a larger SoC. Don't need the physical bulk of a SIM card, or the slot/tray which holds it, or any of the electrical interface components.
And full, exclusive control over SIM cards has great appeal to device operators. For obvious reasons. In practice, eSIMs can effectively be used as the new way to "carrier lock" devices - I doubt that switching carriers will only require "a simple phone call", at least not before some CRTC-mandated regulations are written to explicitly require it.
04-08-2018 08:08 PM
@makkahn28 wrote:Hi. Luddite, The Signature in my Profile settings is not showing, no option for me to do so.
Shame
OK, sorry.
So you'd be stuck creating a macro to easily enter a phrase at the bottom of your posts.
04-08-2018 06:29 PM
@horemansus wrote:Would someone slip their PM sim card into one of these and put us out of our misery (or doubts, apprehension, or anxiety attacks)
@horemansus I'm 99.9% sure that the Apple Watch 3 LTE does not have a SIM card slot in which anyone could put their PM sim to test it. Instead, the watch uses an "eSIM", which is built into the device. That's the crux of the issue, that PM does not yet support eSIMs. \
More info: https://www.youtube.com/watch?v=gSWZCKue5no
04-08-2018 06:18 PM
Hi. @Luddite, The Signature in my Profile settings is not showing, no option for me to do so.
Shame
04-08-2018 05:05 PM
"Just curious, how did you put that I am Not a Moderator thing? I thought PM Clients, EXCEPT Oracles, couldn't do that?"
@makkahn28 Click your avatar in the upper right >> My Settings >> Personal enter a Signature. It will appear in every post you have made.
04-08-2018 03:29 PM
04-08-2018 09:54 AM - edited 04-08-2018 09:55 AM
@Korth wrote:You can configure the APN settings on an Apple Watch, enable/disable Cellular Data, etc, all the usual smartphone options. It seems to basically be a wimpy tiny-screen tiny-battery iPhone in a wearable form factor. And Apple Watch Series 3 (Model A1860 or A1861) is supported by Telus.
I don't see any particular reason why an Apple Watch wouldn't work with Public Mobile, assuming it's not carrier-locked.
Even if locked to Telus wouldn't it be able to run on PM
Website mentions "Pre–paid accounts and some older accounts aren’t currently supported."
04-08-2018 09:52 AM
I also it works on bell & telus but not in SK... Weird.
04-07-2018 10:41 PM
04-07-2018 09:12 PM
I appreciate information you suggested. In short, only Telus and Bell are providing LTE option for apple watch 3 for now. Sigh~
04-07-2018 05:27 PM
@sdt1 wrote:
@parousia52 wrote:Is it possible PM service can support apple watch 3 LTE service? I can't find any solution on that.
Hello @parousia52! I found the following fine print on the apple website, which would suggest that PM (being a prepaid carrier) would not be able to support the Apple Watch 3:
- Wireless service plan required for cellular service. Apple Watch and iPhone service provider must be the same. Not available with all service providers. Not all service providers support enterprise accounts; check with your employer and service provider. Some legacy plans may not be compatible. Prepaid plans are not supported. Coverage dependent on carrier network. Roaming is not available outside your carrier network coverage area. Contact your service provider for more details. Check www.apple.com/ca/watch/cellular for participating wireless carriers and eligibility.
I am not a Moderator. Please do not send me private messages with your personal information.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
@sdt1Just curious, how did you put that I am Not a Moderator thing? I thought PM Clients, EXCEPT Oracles, couldn't do that?
04-07-2018 04:58 PM
04-07-2018 04:31 PM
PERSONALLY, PM should eventually consider these.
IF Prepaids out there have these privileges, PM shouldn't Limit itself, That would be a FOOLISH and Unfathomable mistake
04-07-2018 02:00 AM
Public Mobile is down low in the food chain. Leading edge stuff like this filters down to this level really slow. I suggest looking elsewhere. Certainly do not hold your breathe waiting for it to happen here.
