Data Usage.
abbeylee
Signed up on 23/04/2019.  At the end of the day I checked my data history and it said I used 19 MB.  Under the data used section it said I used 58.678 MB.  Which is correct?
Thanks,  Abbeylee
@abbeylee, what data history are you looking at?  Is it the one on your phone, or are you looking at the usage history in the My Account module?
Do you send a lot of MMS?  You need data to send MMS, and your device may be recording this amount, but it's zero-rated (not counted) on Public Mobile.  This may be the difference.
mh1983
@abbeylee wrote:
Thanks Triguy, just can't understand why the two numbers are different. Abbeylee.
On your phone, do you have the data usage view narrowed to a specific narrower time range?
abbeylee
Triguy
The amount showing in your self serve account - click on view my usage to see amount used and remaing limit.
