08-15-2023 12:39 PM
05-20-2024 11:25 AM
Good question. The same as mine. How do you get some help in this online wasteland?
03-22-2024 09:35 AM
my PM account locked out after I changed the password
please help me to unlock it.
08-15-2023 02:27 PM
Lottery to win phones? How many points is entry and points are % of plan?
08-15-2023 01:19 PM
HI @Inthup
you can login My Account, then go to Rewards page, and click to go to Rewards partal
Check the Rewards catalogue and the $15 bill credit is one of them
08-15-2023 01:16 PM
here's something to read about redeeming Points...
https://www.publicmobile.ca/en/bc/get-help/articles/redeeming-public-points
08-15-2023 12:54 PM
You need a minimum of 15 points to redeem a $15 credit. If you have 15 points or more, go to Rewards section and there will be a list of rewards you can redeem for.
08-15-2023 12:43 PM - edited 08-15-2023 12:43 PM
Login to your account, go to my rewards, and then browse catalogue. It’ll show you your balance and the different rewards you can redeem your points for.
