Points
Alzoubi
I want to use my points to pay my bill but it went to 1 GB for 15 days and I have sufficient GB SO How can I cancel to pay my bill only
1 REPLY 1
hi @Alzoubi
are you talking about the data for US roaming for Canadian?  the 1GB for 15 days is only for US roaming
anyway, if you need to cancel the original points redemption, ask PM support agent to help
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
