08-17-2019 01:55 PM - edited 05-29-2022 08:04 PM
09-18-2019 12:30 PM - edited 09-18-2019 12:31 PM
These threads about the same issue have been merged.
09-18-2019 12:20 PM
Great news and I'm sure this will help out someone else in the same predicament. Thanks for sharing and enjoy your hard won data!
09-18-2019 12:05 PM - edited 05-29-2022 08:06 PM
09-18-2019 12:04 PM - edited 05-29-2022 08:07 PM
09-18-2019 09:07 AM
@Triguy wrote:Your Ipad maybe limited to 3G.
The data speed will match the speed of the data that is included as part of your rate plan. If your rate plan doesn’t include data, the Add-On will default to be at 4G LTE Speed.
Yup ..for the reason you mentioned for my iPad I only have the basic no data $10 plan in order to get data at 4 G speeds. However because of the problems I will stick the Sim in one of my older phones and just use the hot spot feature until I use up the data. The iPad works fine on wifi.
09-18-2019 08:58 AM
09-18-2019 08:29 AM
@GinYVR wrote:Just note iPad 3G will only connect to 3G networks since it doesn't have LTE, so it would depend on the tower in your area (congestion etc). The latest carrier update is 36.0.1.
That may be it — the 1 GB bonus data I was led to believe is 4G. So perhaps the reason iTunes can’t find and update to 4G may be because the iPad won’t accept 4G speeds.
09-17-2019 09:31 PM
09-17-2019 08:20 PM - edited 09-17-2019 09:33 PM
@BEERhi you could contact Moderator_Team via SIMon ? mark bubble bottom right of the screen to submit a ticket and get them to look into it for you![]()
09-17-2019 08:17 PM
@ChuckYeah wrote:Is it possible this is being recreated by Apple's updates? Have you hooked up to itunes since this last outage? Is there a carrier update?
Same old song and dance... couldn't resist! Hugh Crue fan!
iTunes keeps searching but can’t find the carrier update for Public Mobile. Like you said it’s the same old song and dance but I think PM should look into this and fix it.
09-17-2019 03:33 PM
09-17-2019 03:04 PM - edited 09-17-2019 03:13 PM
Have in past several times posted my problems with connecting my iPad 2 using PM sim with data.
All worked fine for a while but since I received the 1 GB PM data promo all went south again.
---And yes I have changed the APN to sp.mb.com.
---Have rebooted the iPad several times.
-- In settings under Cellular Data it shows "Manage TELUS Account"
---In settings under carrier it does show Public Mobile.
---Connected to iTunes BUT itunes to no avail, keeps searcing and searching looking to update carrier settings.
-- At the top left screen it shows full bars and "Public Mobile 3G"
I'm not loosing sleep over this but why is this happening - Is PM only for cell phones?
The iPad works great and connects to the internet with just a regular Bell Canada Sim.
08-22-2019 03:15 PM
Threads merged (same topic)
08-22-2019 02:35 PM
Thanks but all that was done. Not a big deal because I don’t use the iPad much and it does work perfectly with WIFI. However I do want to resolve this problem - just perhaps I have a bit of OCD HA HA HA .
08-22-2019 02:20 PM
@BEERHere is how I got my iPad to work with Public Mobile.. I am doing this on an iPad Pro with 12.4
Put your SIM card into the iPad
Go to Cellular Data
You should see this:
Click on APN settings:
iPad APN settings
Then you should be able to use Safari.
However Telus blocked shared hotspot.
08-22-2019 12:42 PM
@Luddite wrote:@BEER Swap SIMs with one of your phones. Maybe the SIM is pooched.
Thanks for suggestion --- Also tried that - it seems it doesn't like PM - as previously mentioned - it works with Bell Sim - works bu WIFI - and also works by Personal Hot Spot -- but will not work with PM Sim card --very strange.
08-22-2019 12:22 PM
Hey...hey...hey -- good suggestion ----- Using the same Sim that doesn't work in the iPad and inserting it in my old iPhone 3c and creating a hot spot data connection the ipad works fine . Wondering if the problem could be that somehow it's still set to my old Telus account that I had several years ago ---- have completely re-set several times back to factory settings but in settings under Cellular Data it always shows "Manage TELUS account". Very strange!
08-22-2019 12:06 PM
08-22-2019 12:04 PM
We just use the cellphone hotspot function and get the data to work on the ipad. Don't know if this will help you.
Good luck.
08-22-2019 11:58 AM
I have previosly posted and discussed the subject regarding my problems connecting my iPad 2 by PM Data.
I had previously concluded that the problem most likely was due to the fact that my iPad 2 is an older model. And yes I have set my APN to sp.mb.com and then to isp.mb.com - have also tried to include my PM account and password but each time it connects by data for a few seconds and then disconnects. Also of interest in Data settings it has a link "Manage TELUS Account" but when I try it it shows "Connection Failed".
HOWEVER -----
(1) The ipad works great when connected to WIFI am able to watch you-tube videos, TV etc.
(2) Have just tried it with a Bell Sim card and with it it also works great.
(3) It seems that my iPad doesn't like the PM Data - could the reason perhaps be that my PM data 3G is too slow?
08-19-2019 01:15 PM
@BEER You could also just hotspot off your phone. Not what you paid for, but a workaround.
08-19-2019 01:14 PM
@BEER Just a wild thought that the carrier profile my be wrong. Perhaps the iPhone 4 workaround would work?
Failing that perhaps look through this list for things you haven't tried yet.
- is it all apps that use data or just the browser not connecting?
- toggle airplane mode off/on
- remove sim for 5 minutes, then install and reboot
- go to settings, then general-profile and delete any profiles; details for iPhones here https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323130/highlight/true#M24565
- check network is not set to 2G; use auto, 3G, or LTE
- check for operating system updates
- remove any VPNs
- reset all network settings; you will need to add back wifi passwords after that.
- try sim in another phone and a good sim in your phone
- LAST desperate measure when all else fails; erase all data and restore phone to factory settings
08-19-2019 12:39 PM
@iliketotalk wrote:@BEER ok if thats the case do a network reset if you haven't already
I think the problem may be that my iPad 2 is too old and the latest updates are not compatible. Able to connect to yahoo and safari etc but not to Google . When I try Google I get a pop up security alert. Discovered that many apps wont even load including the simple Gas Buddy app. It's sad but a fact of life now that the expensive electronics one buys are made obsolete in a couple of years just so you are forced to buy a replacement.
08-19-2019 12:25 PM
08-17-2019 04:31 PM - edited 08-18-2019 10:43 AM
@Luddite wrote:@BEER Zounds, that's expensive data - $60/gb.
Actually in my case 250 mb / month is plenty because I mostly use WIFI and only use the data if I'm in the car or somewhere without WIFI. I use data only for retrieving my email and the occasionall google look up etc. I never use my data for utube or movies etc because then it would be eaten up in 10 minutes or so.
PS. For GPS. I also use google maps offline map so no data required for that either.
08-17-2019 03:01 PM
@BEER Zounds, that's expensive data - $60/gb. ![]()
08-17-2019 02:20 PM - edited 08-17-2019 02:28 PM
@BEERthatss odd if you had it working and then it stopped it has been suggested that pm is not the way to go for tablets but I am wondering if you are running a third party app that is interfering with your data such as a data counter for example
08-17-2019 02:13 PM
@BEER , check the self serve to make sure there is data left. Otherwise sp.mb.com is the right APN. Public Mobile does not care what device is used with the service. BTW, smart money does not use Public Mobile plans on a tablet. Think person's best friend.
08-17-2019 02:13 PM
08-17-2019 02:13 PM
@BEERYour iPad could have been blacklisted.
