10-21-2025 12:38 AM
10-28-2025 11:17 AM
@Shirley1011 wrote:Both payments went thru
Is your issue resolved? You will need to contact customer service agent to resolve any billing issues. PM generally does not offer refunds, but if you were charged twice, CSA should be able to help.
Send a private message to CSA through the following link :
10-28-2025 11:12 AM
10-21-2025 05:42 AM
@Shirley1011 Your public mobile account needs to be active to port number to new provider , and then you need to leave active public mobile SIM card in the phone and start the porting ( transfer number ) process with new provider so you can reply YES to the confirmation text public mobile will send you to port the number , once you have successfully ported number to new provider it will automatically close your public mobile account . If you need help from support you can use the link in my very first reply to you to engage support . Hope this helps and best of luck
10-21-2025 05:36 AM
I do not have service with Public Mobile this was paid to port phonrpe number per. Charged twice in error
10-21-2025 05:34 AM
A double payment was taken . I only made payment to allow porting of number asi have left Public Mobile. I do not have serbpvice there
10-21-2025 04:05 AM
If you were over charged. Your extra charge will remain as credit in your account to pay for next month renewal.
10-21-2025 01:02 AM
Public Mobile has a no refund policy so you likely won't be granted a refund unless something faulty with your service.
10-21-2025 12:53 AM
@Shirley1011 If you double check credit card is one charge just pending and the other has posted ? If so the pending charge should fall off . But if both charges have posted the you will have to engage support for refund
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
