Personal unlocking key
FionaTsang
hello. I’ve accidentally locked my sim by entering the pin incorrectly 3x. I’m looking for my personal unblocking key. I can’t get it through my account because I can’t get past the two way authentication as I am not receiving text messages.
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer is in contact with an agent.
It wouldn't have made a difference even if you were able to access My Account/self serve.  The PUK for your SIM cards isn't in there.
@FionaTsang
I have escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
Socrates8567
If you click on the link that ends in 22437 that is a direct message to a csa. It's very straight forward.
The other link is your mailbox here.
FionaTsang
This is going in circles and I can’t get a ticket created
Socrates8567
Hello.
To get your Public Mobile PUK code, you must contact customer support, as it is not printed on the SIM card or its packaging. You can do this by starting a conversation with the virtual assistant SIMon or by submitting a ticket to the CSA. When you contact them, you will need to provide account and security information to verify your identity.
Mailbox here.
