09-28-2025 12:21 PM
I paid twice my payment from Sep 24 to October 24 of 2025. Can I get back overpaid payment or can it be used for next month payment in advance?
I sent this question to agent 3times already, but I never get any answer until now. Who works hard for what? I Feel there is no agent for the customer.??
Can I get help?
09-28-2025 04:26 PM
No, that is not the screenshot that helps is understand. i was talking about what showing on My Account. login My Account and click Payment History, and check what shows there and maybe post screenshot of thar
09-28-2025 04:02 PM
Is this for credit receipt? Then I do not need any action further for using it as a payment of next month, correct?
09-28-2025 12:25 PM
Does Payment history on My Account shows you paid twice? If it does, it should also show the 2nd payment is stored as a credit on the account. Check if you see that amount as Available Funds. If it is there, no action needed as it will be used for next renewal
Or post the payment history screenshot so we can explain (remove personal info on that screenshot)
Or if you like, ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
