Overcharged!
Kodes100
Yesterday I was cut off of a long distance call because Public Mobility said I had used ALL of my available minutes. I had not used ALL of my minutes! I had to pay $5.00 to make any calls today. Please tell me how to resolve this error.
@Kodes100
It sounds like you are on the $15 plan. Next time text your other party and have them call you if they are in Canada.
The $5 long distance Add-on are 500 minutes Canada Wide long distance calls.
If it is out of Canada to specific countries the rates will be different.
What country are you calling to?
good workaround if you need to call so desperately , but too much work, buy addon and then arrange for refund after
Yummy
Do you have $15 plan? Only 100 minutes available. Always check PM account before doing long distance calls.
dust2dust
That was a clever workaround to a problem that we see on occasion.
@Kodes100  are you with limited minute plan or unlimited minute plan?
if you are on unlimited minute plan, usually you just need to reboot your phone once and put a 1 in front of the 10 digits number.  There is no need to buy the $5 add-on
Please open ticket with PM agent and they can likely reverse the transaction if you have bought it wrong
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
