Overcharged
01-10-2022 04:24 AM - edited 01-10-2022 06:21 AM
Hi,
My payment plan is $25 per month. However, I have charged double since June 2021 and I noticed it recently when I was checking my credit card.
Payment
01-10-2022 01:06 PM
01-10-2022 06:24 AM
I'm happy to hear you got such a quick response. Care to share the cause of the double charges? It helps us help other customers in a similar position.
01-10-2022 06:23 AM
Hi,
My issue is sorted. Thank you!
01-10-2022 06:02 AM
When did you activate? In June or have you been a customer before the double charges began? If the double charges have been since activation did you activate online or in store? Did you have an issue activating and have to do it twice? If it suddenly just started charging you twice a month as it appears it has then you are the second person with a similar glitch. Contacting customer support as you have is the right course of action and having the CSA open a ticket with tech team to investigate the cause and rectify it from continuing is the first task followed by a refund to your card on file. Please keep us updated on what you learn as to its cause.
Can you check under your plan details to see if there is anything unusual noted? Recently another customer was being charged every 10 days because the plan details changed to a $40/10 day plan.
01-10-2022 04:37 AM
I have just one account. I sent an email to CS Agent. I hope I will get a prompt response. Thanks
01-10-2022 04:28 AM - edited 01-10-2022 04:29 AM
@shireenbasheer wrote:Hi,
My payment plan is $25 per month. However, I have charged double since June 2021 and I noticed it recently when I was checking my credit card. I have listed my payments below for your kind consideration.
June 14, 2021- $37.95
July 14, 2021- $37.95
Aug 4, 2021- $28.75
Aug 13, 2021- $ 37.95
Sep 3, 2021- $24.15
Sep 12, 2021- $26.45
Oct 3, 2021- $26.45
0ct 12, 2021- $26.45
Nov 2, 2021- $26.45
Nov 11, 2021- $26.45
Dec 2, 2021- $26.45
Dec 11, 2021- $26.45
Jan 1, 2022- $24.15
Jan10, 2022- $26.45
I have been overcharged approximately $190 over the past six months. Please look into this matter and refund me the extra amount.
Kind regards
Shireen
Do you have two accounts? We're customers and can't look into your acccount. You need to contact CS_Agent. Click this link. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
