Overcharge
Ph62
Why did I pay $28.00 in May and $33.60 in June? Is it possible to be overcharged?
@computergeek541 wrote:
@will13am wrote:
@Ph62 , loss of rewards is water under the bridge.  The key is to find a new plan which is lower priced to make up for the lost rewards.  Except for those on the $15 plan, it is quite possible to switch to a new lower priced plan with more data.
When it comes to the loss of rewards, even if Public Mobile were to change its mind, I don't see it being all that beneificial.  Public Mobile would just find other ways to receop those costs.
You are preaching to the choir.
will13am
HALIMACS
@Ph62
I would hazard a guess that you use auto-pay and have 3 years service.
That used to get folks $5 off monthly, but now the change in rewards means you instead build up points.
The good news, is all referrals go from $1 to 1 point (which is equal)
The auto pay discount of $2 is replaced by 5% value of your plan towards points, so for most this will be less favorable.
The biggest downfall is loyalty.   Before, we used to build up to $5 off monthly after 5 years, but now EVERYONE gets 10 points per year, or a maximum of $10 value per year, regardless of tenure around here.
Once you reach 15 points, you can 'redeem' that towards $15 credit on your account by logging into your account portal and going under the Rewards section.
Chalupa_Batman
Hello @Ph62
Public Mobile no longer offers loyalty rewards and has removed them from everyone's account.
https://productioncommunity.publicmobile.ca/t5/Announcements/Upcoming-Changes-to-our-Old-Rewards-Pro...
hairbag1
Could be that you forgot that your old Rewards program has ceased operation and now we get points instead.
https://www.publicmobile.ca/en/bc/get-help/articles/old-public-rewards-program
added from Help Files...
https://www.publicmobile.ca/en/bc/get-help/articles/public-points
