Overcharged
Joanne318
I have been charged twice on my credit card for August. How can this be corrected?
7 REPLIES 7
@Joanne318 and check if payment history shows one or two entries for August
but likely yuu need PM to check and sort out
Joanne318
Thanks. No, there has been no change and no payment pending.
Joanne318
Good question, but no the two charges were on the same day.
Thanks
Chalupa_Batman
Hello @Joanne318
Several people have reported double charges in August, you're not alone. Please contact a CS Agent via these links.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
EDIT: @slusagm pending charges don't last 3 weeks. Pending charges only stay on credit card usually up to 72 hours to be processed.
slusagm
you sure one of them not pending charge? Or Available Funds on My Account does not have the extra money  there ?
you can ask PM to check.
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
HALIMACS
By any chance was it August 1st and August 31st, @Joanne318 ?
If so, completely normal as cycles are every 30 days, not monthly.
If not, and you only have 1 PM account, contact customer support.
  1. Use the ticketing system by clicking here , then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
