Outing Call in my Usage Data Not Mine
Mondocanuck
Why do I see an outgoing call made yesterday in my Usage Data that is not mine? I checked my iPhone call history and confirmed the call isn't there. I never made that call. Thoughts?
Mondocanuck
Yes, the number ended with 4001. I didn't realize my phone needs to make an outgoing call to check for voicemail. Thanks for your help 😀
HI @Mondocanuck
if the numbers are found on this page:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
Then they are just voicemail number only.  Normal
@Mondocanuck  Does the number end in 004 if so this is nothing to worry about and just your voicemail I believe
@Mondocanuck   what number was that?  was it end with 4001 or 4002?  If so, those are voicemail number.  All incoming calls routed to VM or when you checked VM from your phone, all those will be record on the log showing that number
