2 hours ago
- last edited
2 hours ago
computergeek541
I am unable to make outgoing calls but receive calls and can text fine. My husbands phone works fine. Any update on what is going on and when it will be fixed.
2 hours ago
yes, there was problem this morning
https://productioncommunity.publicmobile.ca/t5/Get-Support/Alberta-Voice-problem/m-p/1243328#M858105
some said the issue is resolved and they can make and receive now. Telus also removed the outage note. Try reboot the phone, try your sim in another phone if possible. If still cannot make calls or receive, ask PM to check.
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
2 hours ago
Apparently there has been some outages.
https://www.telus.com/en/qc/outages
Look up your area. And also check the Announcements section here on the forum.
