3 hours ago
- last edited
3 hours ago
computergeek541
My daughter’s children smart watch doesn’t detect the SIM card. I checked the SIM card with my telephone, it’s working and as well as I restarted the watch many times but still doesn’t work.
29m ago
the watch not support the PM sim card frequency, so it will not work sadly
2 hours ago
I used a child's smart watch (actually a pendant) with a nano SIM a number of years ago. To make it work with Public Mobile I had to change the APN settings. This, however, was done via a text message to the watch so I'm not sure if that is working with yours. The watch couldn't text message for the user, but you could send / receive a text for changing settings.
BTW The watch was a lil Tracker. I'm not sure what you've got or if it's similar as I think a number of the watches are rebrands of the same device. We kept the pendant until my son was bicycling and it smashed against the handle bars ... oh well. We're using an Apple Watch now, but that required a mobile hotspot to get it working with Public Mobile (and another round of fighting with the APN settings).
3 hours ago
I have changed the in my mobiles settings for this SIM card Preferred network type from 5G to 4G.
3 hours ago
@eddieO wrote:@Naveed12 I'm quite sure that Public Mobile does not work on smart watches including the Apple Watch etc. only phones
There's nothing stopping a smartwatch itself from being used at Public Mobile. If the phone has a SIM card slot (which ths customer's watch does) and is compatible with the network types and frequencies, it will work at Public Mobile. In the case of an Apple watch, Public Mobile is disallowing the eSIM registration.
3 hours ago
She used a SIM card before, the same but from different operator. It was working
3 hours ago
3 hours ago
@Naveed12 wrote:My daughter’s children smart watch doesn’t detect the SIM card. I checked the SIM card with my telephone, it’s working and as well as I restarted the watch many times but still doesn’t work.
I'm suspecting a possible network type/network frequency issue. Which model watch is this?
