2 hours ago
I am unable to make out going calls, I can receive them. as well as texts, and send texts. I have done all the resets, all to no avail. What is going on with Public obile?
19m ago
I also live in BC and am having the same problem.
38m ago
i am having same issue and live in BC.
44m ago
Having same problem last 48 hours... just put in a help ticket.
2 hours ago
some said the issue is resolved and they can make and receive now. Telus also removed the outage note. Try reboot the phone, try your sim in another phone if possible. If still cannot make calls or receive, ask PM to check.
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
2 hours ago
I am dealing with the same issue, all day Aug 19th. Does Public Mobile have any kind of service update, just so I know when it should work ?
2 hours ago
@computergeek541 wrote:
@Dan-Cebuliak wrote:I am unable to make out going calls, I can receive them. as well as texts, and send texts. I have done all the resets, all to no avail. What is going on with Public obile?
Are you in the western part of the country? There was a Telus wireless outage earlier in the day.
Been an on-going issue for most of today. Woulda been nice if Public Mobile / Telus kept us all updated with any info. If nothing more, to let others know it's a system issue rather than on customer end.
2 hours ago
