07-01-2022 07:08 AM
Hello.
Why do I get this message after the renewal date and have to add more minutes?
Thanks.
Payment
07-01-2022 08:05 AM - edited 07-01-2022 08:09 AM
07-01-2022 07:56 AM
I'm on the $25.00 plan. Yes the calls still works. Thanks for your reply
07-01-2022 07:30 AM - edited 07-01-2022 07:35 AM
@Hunter11 hi what plan are you on? in your self serve under data and add ons what does it say for minutes used? if your phone is still able to make calls then disregard meessage they are often sent out in error
