07-01-2022 07:28 AM
I needed to suspend my account, upon reactivating, the auto pay reward and one another disappeared. Do I lose them?
Rewards
07-01-2022 09:13 AM
@1981rz did you suspend via Lost/Stolen? If that is the case, then YES , they might "disappear" but PM Support can help to restore them.
But if you suspended via non-payment, then they should be still there.
Either way, you can open ticket with PM Support to have it sorted out:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-01-2022 09:08 AM
@1981rz you can submit a ticket to CSA and ask if you are eligible to have he missing rewards to your Available Funds.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
07-01-2022 07:33 AM
@1981rz hi yes if you suspend your account fo any reason you will lose rewards for this cycle they will return next renewal
