Sim card
Peter27
No sim card detected even though i have one in phone.
This keeps happening off and on.  Will sit for an hr and come on then work for 10 minutes and shut off
sayin no card. I have tried putting card in to other phones and it says same.  no card detected.
It did this about a month ago with same problem then started working and now its worse.
Pulled card in out and still no connection.
Total bummer
7 REPLIES 7
@BKNS27 wrote:
@Peter27
Try resetting the Network settings on your phone to see if that helps. Also, try the SIM in another phone to see if it has the same issue. If it is then it is your phone. So bring it into a cell repair shop to have it checked out. It should be free for a diagnostic.
Since the SIM card isn't being detected by the device as being in the phone, resetting the network settings wouldn't fix the issue.
Peter27
Thanks for all the replies.
On the way to get sim card and phone stated to work again.
Strange. Anyway i have card and next down will install it.
@Peter27  Once you have new SIM card in hand in your account notice “change sim “
Tap it then enter new SIM card number or use the camera app on phone to eneter it for you
Once that’s done wait few mins and reboot the phone that’s it @Peter27
hi @Peter27
Yes, we can guide you through
But a sim Public Mobile sim card from Telus or Koodo or MobileKlink store for $10 ( https://myaccount.publicmobile.ca/en/account/purchase-sim) or buy from Amazon for $5 ( https://www.amazon.ca/gp/product/B06X9ZGDWG/ )
Then login My Account using browser, go to Profile page, click the pencil besides the sim card number and you can update the new sim card number there
Last reboot the phone and it should work
Peter27
Thank you. Can you guide me through that process
@Peter27
@Peter27  Maybe try pulling SIM card out and gently wiping down the contacts on it and try it again , if same might be broken SIM card and need to replace it , pick new one up from Telus Koodo store or order from Amazon . Then log into your account and sim swap the number
