Current Plan Coverage
dogh
My current plan provides 125 GB in Canada , US and Mexico. If I am in Mexico does this plan eliminate the need for a Mexican SIM Card?
2 REPLIES 2
CharlieWhisky
No need for a Mexican card. You can use your phone just like in Canada.
All you need is to activate roaming and manually select AT&T or Telcel
porcupine
Yes it does make sure you turn on roaming then select your Mobile network settings turn off automatic and pick manually
