Ordered and paid for phone not received since
basiav
My Mastercard was charged $222.88 on Dec 20, 2022 for a refurbished Galaxy A013, but the phone never arrived. How can  get my money back?
8 REPLIES 8
basiav
Thanks
basiav
Thank you, very helpful
basiav
Thanks!
basiav
Thank you!
darlicious
@basiav
When you contact customer support they will open a ticket with the CPO Phone department. Make sure you submit the order #, email used for the order and your shipping address. Did you try checking the tracking # to find out what happened? Did the shipper (usually UPS) return to sender? The more info you can share with customer support the quicker the resolution. Contact customer support as previously supplied above.
@basiav that has been long and unreasonable.
you really need to open ticket with support for status update
message them here:
HALIMACS
@basiav
Contact the customer support agents and request a refund.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
LoveNature
Hi @basiav
open a ticket with SIMon Chatboth
typ: Agent
and Click, Contact Us
then Click, Other
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
