04-08-2023 06:02 PM
What happens to existing rewards if I opt to transfer to Public Points? Do I lose them?
04-08-2023 06:08 PM
Just in case you want to really check it out, here is a comparison of the old vs new:
in summary
On the other hand, the goodies for new system,
- 5% Points back for add-on purchases as well
- add-ons are around 33% cheaper when you redeem with Public Points
- you can use 1 point for lucky draw, so, technically you bet $1 and can win an iPhone
04-08-2023 06:06 PM
@ianburden wrote:What happens to existing rewards if I opt to transfer to Public Points? Do I lose them?
A conversion forumula will be followed to turn the old rewards into points. However, I strongly recommmended agianst changing to points. The old rewards system is better in almost all aspects.
04-08-2023 06:05 PM
@ianburden Yes you'll lose the rewards and will not be able to go back to them so most (all) here would recommend that you don't switch to new public points as the new points offer much less value than old rewards overall.
04-08-2023 06:05 PM
@ianburden don't change!!!!
you move to Public Points and you loss your current rewards. Your current rewards from the old system is MUCH MUCH better
