Opening an account
Hermit
Site re app does not accept the verification code to start a new account.
11 REPLIES 11
Hermit
Yes, I know. My issue was I tried to open an account from within the app. My bad.
Hermit
Thank you. I found that out the hard way.
Actually, you WILL need the app @Hermit to do the activation.
Beyond that, all can be done on the website login to self-serve.
Hermit
Yes, thanks. I think I found the issue. Was trying to sign up through the app and you’re supposed to do it on the website
@Hermit
While submitting a support ticket is sometimes the only option, there are usually workarounds which help get things restarted or completed.
Did you try the suggestions offered by @hTideGnow ?
Hermit
It is on her phone and her email. I will submit ticket. Thanks for the link
@Hermit  Not aware of any one thing for setting up a new account . There’s so many issues with PM one can’t pin point it to just one thing . But to start make sure your using a different email then the one used for your account . All accounts need there own email and it’s best to download the app on her phone to complete the activation
Hermit
I have an account but this is a new account I try to open for my spouse
Hermit
Thanks. Starting that now.
are you aware of an existing issue for setting up new accounts?
Hi @Hermit
do you have service with PM yet?
try uninstall the app, reboot and reinstall and re-login,
if same, please submit a ticket with CS Agent here:
@Hermit  Please submit ticket with support
send  a  private message   To CS_Agents
