3 hours ago
2 hours ago
hi @Yummy I suggested message, not that I don't like Chatbot, but usually people have bit joined PM yet and Chatbot does not work when you don't have a My Account
So, if that is the case for you @Ibrahim11 , olease DO NOT evem try Chatbot, use direct message
2 hours ago
Open a Ticket, do NOT send direct message to agent. It is against the rules (unless chatbot is not working).
IF SIM is not shipped, agent might be able to cancel your order and refund you.
2 hours ago
hi @Ibrahim11 sim card order cannot be cancelled and no refund
you can try to contact support agent, but answer likely the same
pls message them here
2 hours ago - last edited 2 hours ago
@Ibrahim11 It might be possible if you just did it and it hasn’t left the store ,
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
