12-14-2023 08:38 AM
Hello, my old phone had an esim and it is no longer working. I bought a SIM card for another phone but i can't get into my old account because if the eversafe and i can't access my old email either. I need help getting my number back and on the new device.
12-14-2023 08:45 AM
Thank you I have submitted a ticket.
12-14-2023 08:43 AM
You can simply message support and they can update the account with the sim card number you have. Please message them here:
12-14-2023 08:42 AM
@KSMBoulter If you can’t log in submit ticket with support to SIM card swap the number for you to the new physical SIM card you have . Then you will get code sent to that new sim card to log into your account again . And keep same phone number and plan
send a private message To CS_Agents
