12-13-2023 08:35 PM
Hello. Is there a way to switch from a regular sim card to an eSIM on an existing account?
My Account
12-14-2023 08:07 AM
It worked! That you very much.
12-13-2023 08:43 PM
Just one peice of knowledge to add here, note that eSIM's are non transferable. Once you transfer to an eSIM, something happens to that phone or you buy a new one, you can not transfer it. You will have to purchase a new eSIM.
12-13-2023 08:41 PM
To transfer to eSIM, , you have to buy for $5.
To buy new eSIM, First, download the ap on your new phone, click ⊕ or ⧁ at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now. You can buy and install eSIM from there
12-13-2023 08:38 PM - edited 12-13-2023 08:38 PM
@Matoot11 Yes there is on the phone you want esim download the PM app and go to subscription add on page . Notice shop SIM card at bottom in my screenshot tap it and choose eSIM . Download and install that’s it . You will keep same phone number and plan no worries
