11-29-2023
05:29 PM
11-29-2023
06:56 PM
computergeek541
I switched from Roger’s on Sunday, I responded yes to the text messaged authorizing the number port, but I haven’t been receiving texts or calls. How do I check to see if the port was done properly or have it ported again? Thanks!
12-04-2023 01:14 AM
12-04-2023 01:08 AM
The same thing has happened to me while porting over from Virgin. Approved the transfer text message from Virgin but my public mobile sim does not recieve calls or texts. Old virgin sim is still working
11-30-2023 02:34 AM
Hi there I am having the same problem can u please guide me or send me the number also and my old provider Sim is canceled no longer works
11-29-2023 05:34 PM
@LynnMac Ok so call the number I private messaged you and the will re trigger request for you
11-29-2023 05:33 PM
Thank you! I just checked and the Rogers sim still works.
11-29-2023 05:31 PM - edited 11-29-2023 05:34 PM
@LynnMac I’ll send you the porting team number private message and they can re trigger the port request for you . In the mean time you can check to see if the rogers sim still works . If it does the port was not complete
