Subscription Change
Tyso
Hello
I recently changed my subscription plan to the $34 for 40Gb black friday subscription. However, it no longer says that this new subscription will change over on the 14th December like it's supposed to. Can I confirm this will happen and you will value the $34 for 40Gb subscription?
Kind regards
XxSimranjeetxX
Could you please elaborate that how we can get Subscription, and Loyalty rewards like you? Thank you. 😁
@Tyso  Check your payment page like this mine set to renew on that plan to dec 27!
TheSterlinger
If you check on subscriptions it should say Upcoming Subscription. https://myaccount.publicmobile.ca/en/account/my-plan-add-on
If it doesn’t shop up you can submit a ticket to a Public Mobile CS agent. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
