12-03-2023 04:57 PM
HI,
I don't want subscription anymore, how can I remove my credit card?
Thank you a lot!
12-04-2023 07:18 AM
@XxSimranjeetxX Yes with PM if you port your number out to another provider successfully your account will be closed automatically
12-04-2023 04:27 AM
I transferred from Fido to PM. Fido customer care told me that they will keep my account as it is until I decided to transfer back to Fido in future. Does PM have different policies if you port your number to different service provider because it is prepaid instead of postpaid?
12-03-2023 05:12 PM
It really shouldn't be necessary that we have to contact support reps to remove our credit cards from our accounts. Why Public has not corrected this by now I don't understand or why any company would be permitted to do this.
12-03-2023 05:07 PM
@mliulian If you want to keep your phone number you just need to port the number out and it will automatically close your account also
12-03-2023 04:59 PM - edited 12-03-2023 05:00 PM
just disable Subscribed and your account will not renew...then in 90 days it'll be deactivated. Once you port out, your account will also deactivate.
added pic
12-03-2023 04:59 PM
Hello @mliulian
You have to reach out to a CS Agent to remove the card.
